Door Codes
Old Jan 26, 2009 | 12:32 PM
ToolTime's Avatar
ToolTime
Talking Door Codes
Dont know if Im in the right forum. Can anyone tell me how to find and then re-program my door codes?
Old Jan 26, 2009 | 01:18 PM
briank's Avatar
briank
I believe if you remove the panel below the steering column, use a flash light then look up to the left of the column and you should see a white box with 5 numbers on it. I could be wrong where it is located.
Old Jan 26, 2009 | 01:23 PM
birchy's Avatar
birchy
There are a few threads on this topic if you do a search for "keyless entry code"..
I found mine the other night by doing that. If you stick your head down by the pedals and look up in the direction of the drivers side rear view mirror, you will see a white box with 5 big, very obvious numbers. This is your factory code.
Old Jan 26, 2009 | 01:24 PM
pitrow's Avatar
pitrow
The location varies with the year and the vehicle, but a little searching on here should turn up the location for you. If all else fails you can take it to the dealer and they'll scan it for you, but they charge an hour labor for it.
Old Jan 26, 2009 | 02:28 PM
ToolTime's Avatar
ToolTime
Thanks fellas, I will go check right now!
Old Jan 26, 2009 | 07:39 PM
ToolTime's Avatar
ToolTime
Found it thanks! Is the code on my Expy the same factory code for all Expy's, or is it exclusive to my Expy?
Old Jan 26, 2009 | 07:46 PM
briank's Avatar
briank
It is just for yours.
Old Jan 26, 2009 | 07:47 PM
birchy's Avatar
birchy
Exclusive to yours I would imagine.. else anybody could get into anybody else's.
Old Jan 26, 2009 | 10:01 PM
ToolTime's Avatar
ToolTime
Thanks again!
Old Jan 27, 2009 | 05:40 AM
projectSHO89's Avatar
projectSHO89
It's in your owner's manual. Look in your glovebox.
Old Jan 27, 2009 | 08:37 AM
alloro's Avatar
alloro
Sorta kinda. Since it's only 5 digits there are only 100,000 possible combinations (00000-99999). So if the numbers are sequential, every 1 in 100K vehicles made with a keypad, share the same code.
Old Jan 27, 2009 | 02:31 PM
Quarterbore's Avatar
Quarterbore
I am still searching for mine but I didn't try this location yet (mine is a 2000 XLT). I can say it is not in the owners manual, I looked
Old Jan 27, 2009 | 03:26 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
try this link and hopefully it will help(and work):
WikiAnswers - The Q&A wiki
Old Jan 27, 2009 | 03:46 PM
Quarterbore
Well, I did try that and I may need to go that route yet...
WikiAnswers - How do you find codes on 2000 expedition
Old Jan 27, 2009 | 07:28 PM
ToolTime's Avatar
ToolTime
I looked under the dash as directed and whalla there it was. So, when you are under the dash, look to the right kinda like by the fuse block deep in there. good luck
