Sponsored by: Real Truck
electrical problem
Old Jan 26, 2009 | 12:09 PM
FORDTOTHEBONE's Avatar
FORDTOTHEBONE
electrical problem
I have a 2001 F-250. I have no power back at the trailer receptical. Can anyone tell me which relay under the hood is for the trailer receptical. There are two pairs of relays beside the big box of fuses. Is there a way to use an ohmmeter to test a relay to see if it good or bad?
Old Jan 26, 2009 | 01:16 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you have any identical relays in there, just swap them for test purposes. Check the P/N's, then swap.
Old Jan 26, 2009 | 01:21 PM
FORDTOTHEBONE
Thanks! I will try that.
Old Jan 26, 2009 | 08:25 PM
Beerstalker's Avatar
Beerstalker
Also you can download a copy of your Owner's guide at
www.motorcraftservice.com
It has the fuses and relays listed in a table.
Old Jan 26, 2009 | 09:02 PM
ReAX's Avatar
ReAX
You can test a relay, but it's not very easy.
A normal relay will have five terminals. The ones marked 86 and 85 are for the coil. 30 is the pole (what your controlling), then 87a is connected to 30 when no power is applied to 85 & 86. When you power and ground 85 & 86, the 30 terminal connects with 87. To test the relay, put your DMM or OVM on the 30 and 87 terminals, then ground the 85 and apply power to the 86 terminal. With power across the coil, you should read very low ohms on the 30/87 terminals.
To test the coil, it should take 200-750mA (hopefully more toward the 200mA.) Use the Amperage setting on the DMM to test the draw. If it doesn't draw or draws more, the coil has shorted.
Old Jan 26, 2009 | 09:04 PM
ReAX's Avatar
ReAX
If your not familiar with a DMM, take a glance over this http://sites.google.com/site/reax222...attredirects=0
It will help out in setting up the connections.
