question on flowmaster outlet
Old Jan 26, 2009 | 07:21 AM
stumpbuster's Avatar
stumpbuster
so i decided to take off the "stock" outlete pipe from the dual chamber 40 series i installed awhile back, cuz i wanted to have a different look.
i wanted to dump it right b4 the back tire, which i did this weekend, using a 90 degree steel adapter i found and a 25" piece of 3" ss tube.
(that ss piece cost 70 bux)
anywayz, it didnt change the sound much, which is fine, i love the look, but am worried that "the sharp 90 degree coming out of the muffler might be too tight"??
effect performance??
any input??
Old Jan 26, 2009 | 08:21 AM
dkf's Avatar
dkf
If it is a smooth bend that isn't collapsed at the bend, no worries.
Old Jan 26, 2009 | 08:28 AM
stumpbuster
def a smooth bend, 3" throughout.
thanks alot for the reply
i was just 2nd guessing maybe cutting it back closer to the cat, but then again 3" is a rather large diameter for breathing.
Old Jan 28, 2009 | 10:28 AM
WeWonIt's Avatar
WeWonIt
Should be fine, why not just go with a 22" X 4" echo chamber "slant cut tip" ? You can normally pick one of those for about $35-$40 in SS.
Old Feb 4, 2009 | 11:02 PM
1966Tbird's Avatar
1966Tbird
i agree i hate flowmasters everyone has them and everything i've been in with them has droned at some speed or another
Old Feb 5, 2009 | 07:22 AM
stumpbuster
thanx for the input tbird
Old Feb 5, 2009 | 09:42 AM
Bear River's Avatar
Bear River
Former ******
Everyone you know is running that stupid 40 series. You need the 50 series.
