Sponsored by: Real Truck
Brake Controller
Old Jan 26, 2009 | 12:06 AM
cowboyscash's Avatar
cowboyscash
Brake Controller
I have a problem with the tow comand system that the dealer
can not seem to answer.The trailer brakes work just fine
but the display only reads out on the tow comand controller
to show power and gain.When I use the message center
in the IC display it brings up the display for the tow comand
but the power and gain alwas stay at 0 even thou the brakes
are working and the display on the controller are showing
power and gain output like it should.I had the recall flash
and that did not fix the IC for this problem.Any ideas
Old Jan 26, 2009 | 05:01 AM
celjel's Avatar
celjel
Mine does the same exact thing. I figured I would have them look at it when I take it in for its first service, so I really can't answer why it does it but would like to know myself also.
Old Jan 26, 2009 | 09:33 AM
Weiss's Avatar
Weiss
Mine does the same also dealer told me it was normal.Let me know if you hear different.
Old Jan 26, 2009 | 09:51 AM
senix's Avatar
senix
that is the same as mine. I would assume that is the default display.
