hi i have a 97 ford f 350 with the e40dtrans with an edge evo chip and stage one injectors and i have just blown my 9 transmisson and the longest any of them have lasted was 6 months, 10,000 miles whats wrong with this POS ???? do i just say the heck with it and swap it out for a zf5?
yea but any idea of what kinda money im looking to put in it to swap it over i was figuring on around 4 grand for a new zf5 with a double disk clutch and all new parts
idk I got mine used for $1000,00 and put another $1400.00 into parts to get it in so it depends on the deals you find. that was cheaper then a new rebult auto for 4 to 5 thousand. So I went that rout. So i saved $1000.00 or better.Just depends on what you can find for deals and parts. Its also not the most easy swap to do but it can be donr depending on your skill level.
i know i can handle doing the swap over but the reason i kept going with the auto was i was got the last one threw ford for 1700 bucks with the new torque converter what did you do about the wireing harness and the computer?
will the brain i went to a junk yard and bought a mannuel brain. The harness is the same from 91 to 97 but where the wires are in it are diff. I i had to move one wire to a diff. location in the plugin to get it to turn over, but if you get a harness for the same year as yours you wont have a prob. with it
so the easyest would probly to be just buy a wireing harness for a manual ? cause the comp and the wireing was the only thing that concerned me about the swap
ya. see i bought mine with everything pedals harness all so it was a good deal and it was all there,but the brain,and if your real good you dont need any of it .you can rewire it and trick the auto brain into thinking its a man. tranns but that was a little much for me to try on my first try. lol
The EVO tuner is the likely culprit for the trans failures. A custom burned multi-tune chip from TW <--click, is easier on the trans. You can get as many tunes as you can afford.
Get a larger trans cooler <--Click, heat is the cause of most trans failures IMO. Especially with larger injectors and a hot tune (EVO).
A BTS trans <--Click, is bullet proof but pricey....+$5000. His warranty is second to none. You break it he fixes it...period.
You can build a stout trans for around $3000 including a $1000 Torque converter. I got my parts from HERE.<--Click
9 transmissions!
Did they have a common failure?
The edge tuner is for stock sticks.
You also could just build your own trans.
Parts kit link Racer X Automotive
i have had just about every thing you can imagine fall apart valve body failure oil pump problems planitary gears, clutch packs slipping however the trans temp very rarley gets above 160 on the temp gauge and im running 3 stock oil coolers in the front
no 5 of them were from a local shop who had a pretty good rep well untill they met me lol the rest were from ford lucaly i have only had to pay for 3 iv bein able to keep going back under the warentes
