Sponsored by: Auxito
Battery light always on?
Old Jan 25, 2009 | 07:49 PM
psu1xj's Avatar
psu1xj
Hi!
Had some weirdness with my '01 F150 (4.2, M5OD, 2wd) today. When I first started it, it ran ROUGH and the "Service Engine" light came on. I shut it down and started it up again and things smoothed out. But, it had entered three codes into memory: Miss Cyl 1, Miss Cyl 3 and Lean on Bank 2 (IIRC).
As it was running fine after that, I erased the codes to see if they'd show up again and they haven't.
I drove it several times today for a total of maybe 50 miles. The last time I started it up, the battery light came on and stayed lit. And now it's always lit.
My manual only lists a bad Alternator, fault in alternator circuit, or loose belt as possible causes.
Would I be right to assume that I need to swap in a new alternator first and see if that fixes it?
Would I also be right to assume that a 4.2L manual tranny truck with no power ANYTHING probably just needs the 95A unit?
Thanks!
-Sam
Old Jan 25, 2009 | 09:14 PM
LxMan1's Avatar
LxMan1
There is also an alternator fuse in the power distribution box under the hood. Check it too.
You can usually go by most AutoZone stores and they will test it on the truck.
Old Jan 25, 2009 | 09:30 PM
psu1xj's Avatar
psu1xj
Hmmm.. Hadn't though of that. I'll check that too, then. Nearest AutoZone or anything similar is almost 20 miles away. Wonder if I'll make it that far on just the battery? Thanks! -Sam
