has anyone done this before? what gauges did you use and how did you set it in the dash? how hard is the wiring job. 87 f/s 351w 4 b carb. please let me know if it is worth doing. thanks den7bronco1
32 people looked but didn't think it was relevant to comment that no they hadn't done the digital gauges conversion or to comment that it wasn't worth doing,
and as far as it goes it wasn't even worth commenting on at all.
But I will, it's not worth doing, it's an 87 Bronco.
I found one a while back for the 70s Ford trucks and the 78-79 bronco.. if I remembered the site, they might have had one for the 87 bronco.
was about $800.
you would need a mechanical to electric sender, again. some other site I found had one for most of our transfer cases.. then you could just make your own custom dash
I think digital dashes are awesome, I personally think it's worth looking into. It's especially great on these older vehicles as noone expects it
