Sponsored by: Real Truck
E Brake Problem
Old Jan 25, 2009 | 12:40 PM
DJE2001's Avatar
DJE2001
E Brake Problem
Ive got a problem with my 2001 F350. Whenever I drive more than about an hour or so, after i come to a stop then start going again (coming off the highway for example then starting to drive after being stopped for example) my e brake is seizing up and as i start to drive i can feel it locking in my rear wheels for the first few seconds then the truck drives normal again. Anyone ever have this happen before or have any suggestions? Thanks.
Old Jan 25, 2009 | 12:53 PM
Lou Braun's Avatar
Lou Braun
I'll bet that one of the two rear e-brake assemblies has come partially apart inside. Another FTE user reported a similar problem.
This will reqire pulling the rear rotor assembly to inspect the e-brake. If you are very lucky the first wheel you will work on will be the culprit.
Lou Braun
