Crossover Pipe Installed, It's worth it.
Old Feb 25, 2002 | 07:58 AM
cigarxtc's Avatar
cigarxtc
I had the local custom exhaust shop put on the crossover pipe, Friday after work. It makes the 351m dual exhaust sound deeper and throatier! I also feel the low end torque that was not present before. If you're running true duals, I highly recommend adding a crossover pipe.
Old Feb 27, 2002 | 01:07 PM
bufordt's Avatar
bufordt
Did you install it before or after the 02 sensor? And about how big of tube did you use?
Old Feb 27, 2002 | 01:19 PM
cigarxtc's Avatar
cigarxtc
I forgot to mention it's installed on a 78 F150. There are no cats or O2 sensors. The crossover pipe is 2.5", same size as the exhaust piping.
Old Feb 27, 2002 | 10:06 PM
76RangerXLT's Avatar
76RangerXLT
