302 motor numbers.
Old Jan 24, 2009 | 10:06 PM
restoringmy46's Avatar
restoringmy46
302 motor numbers.
I need to find out where the motor numbers are so I can tell what year the motor is. I have a 75 F100 that is suppose to have a 86 model 302 in it. Where on the motor can I find the numbers at. I need to know the year so I can order my comp cam kit. Plus I have 2 more that I need to know. A 351 Modified and not sure what the other is. Comp said a 1985 or 85 used a "31" perfix to let you now this is a factory roller cam and a 351 used a "35" prefix. Is this in the Vin # on the truck or is it on the motor somewhere. B/c the motors are not the original to either truck. This is why I need to know where the numbers are on the motors. Thanks Scott
Old Jan 24, 2009 | 10:18 PM
Conanski's Avatar
Conanski
Block casting numbers are on the rear side of the block near where the starter mounts, you'll need an E7TE casting to be 100% sure you have a block that's machined for a factory roller cam, some earlier blocks may be partially machined or cast as a roller block but not machined at all. The roller blocks had taller lifter bores and bosses in the valley for the spider assembly.
Old Jan 24, 2009 | 11:22 PM
restoringmy46
Thanks, I'll take a look tomorrow. I'll look for the E7TE casting. Comp mentioned the taller lifter bores to. I guess the intake has to come off to check the valley out. I'll do that to once I find out what year it is.
