It's alive!!
Old Jan 24, 2009 | 08:40 PM
WA-SuperPickle's Avatar
WA-SuperPickle
Thumbs up It's alive!!
"The Super Pickle" fired up today, and I want to send a big "THANK YOU" to all of you who helped me out with this!!
After we let it warm up a bit, and made sure nothing was leaking, I drove it around the block, and had a few fond memories come to mind.
The final two things that were done today were:
  • New points installed (though the old ones looked good after removing them)
  • New plug wires
Thanks to CS65/D.W. for helping me with figuring out wher the #1 plug was on the distributor cap, after I had removed all the wires, only to notice that it wasn't marked on the cap! DOH!
Anyway, now I'm going to go through and shorten up some wires that are too long and "coiled", trace some "unknowns", and make sure to hook up all of the "other electrical" (Tach, backup lights, CB, am/fm radio).
All that along with greasing all of the zirc fittings, replacing all of the u-joints (or greasing them?), adjusting the steering (slop), and topping off the axles w/ gear oil.
Couple of things; any way to "lube the windows"? The driver's goes down easy 1/2 way then stops. The passenger side is REALLY stiff, so I decided not to force it.
A shop manual is next on my list, along with a new pair of wipers (from NAPA?) NAPA had the hook up on the plug wires today, had them IN STOCK! You guys were right, they ROCK!
Well, thanks again; I'll be bugging you guys with other questions about this old girl, but so far I LOVE 'ER!
Oh... my wife even smiled at me for the "kid with a new toy" look I had on my face this afternoon.
Ciao-4-Now
Old Jan 24, 2009 | 08:56 PM
camperspecial65's Avatar
camperspecial65
Hot damm...glad to hear !!!
Lube...just grease the u joints and other zirc fittings...there arent many...just do it just so the seal fills up...many fill till you see it pop out...that defeats the pourpose of the seal initiially..
steering slop...these trucks have lots...moreso on 4WD...assume it hasnt had a rebuild in a long time...not too hard, but time consuming and kinda spendy if money is tight..
the wiring...hold off on that for the time being till I can get a look at it in the flesh...prolly gonna run south next weekend at some point.
Im glad ya got it going...other things I would do....change oil/filter...check trans and transfer case oil levels on the flat...same with the front and rear diffs...
Check brake fluid level and have a looksee for wet/damp backing plates or where the flexible lines connect.
Other then that...sounds good...I would also keep the battery undone when you arent tiunkering...just in case theres a draw in the wiring somewhere...as it looks, I wouldnt be surprised.
- cs65
Old Jan 24, 2009 | 08:57 PM
Orange '63's Avatar
Orange '63
That's awsome! Glad to see all your work finally paying off.
Old Jan 24, 2009 | 09:17 PM
WA-SuperPickle
Thanks guys! I have a couple more questions... The 4-barrel that's on the truck now has some problems.
  1. Choke is STIFF and it looks like it was converted to a manual from an auto
  2. The 'accelerator pump'(?) on the secondaries (the little arm thing that sticks out of the square housing w/ a round stamp in it?)- The arm is broken off and not functioning
Question: should I look at getting another/new carb, or fix this one? Seems to flow fuel ok? Can I get those parts?
Also, the emergency/parking brake is stuck (in the 'off' position thank God), what's the best way to address that?
OH, and one of my saddle tanks is FULL of bad gas (I thought they were empty). Where can I have it drained safely/responsibly?
Old Jan 24, 2009 | 10:00 PM
Redmanbob's Avatar
Redmanbob
Carb, would need picts to advise and that would be iffy honestly without a birds eye view.
E Brake, mine was the same, truck sat forever. Take some penetrating oil and squirt the topside of the tract opposite the carriage mount.pull handle. The top side is an open tract and can be oiled. I'd hit it with any rust breaker and solvent etc.. Diesel/Tranny fluid 50/50 whatever.. then rapp the tract tube with a wrench or ?/ to shock the rust weld. Tug the handle with caution and repeat till it frees up.
My choke was stiff too. The screw to adjust it was too far out and it snagged the cam when being pulled. Have someone actuate it and watch it. Then adjust accordingly.
Sure glad to hear se is barking to the music!! nd that the gal is happy for you!!! Take her(little woman) for a good Sunday ride in it with a picnic basket/bottle O wine after you get the old girl trustworthy. Be a damn good afternoon you two wont soon forget!!
Old Jan 24, 2009 | 11:57 PM
SJ Bikesaws's Avatar
SJ Bikesaws
KUDOS!!!!!
Acc pump housing fits 2v autolites and some motorcrafts if its the old autolite 4v.
Old Jan 25, 2009 | 08:35 AM
drof46's Avatar
drof46
My wife did the same when I got my old 64 going and drove around the block. Good luck on the other stuff she needs.
Old Jan 25, 2009 | 11:55 AM
grm61's Avatar
grm61
Congratulations! You got a four barrel eh, got pics? Greg
Old Jan 25, 2009 | 12:27 PM
daveengelson's Avatar
daveengelson
Congrates, if recall mentioned truck has been setting for awhile so strongly suggest checking the fuel filter and either clean or replace filter. Understand it should be attached to the fuel pump, if don't have one then either use an inline filter or attach a canaster type to driver's side inner fender. Again, congrates!!
Old Jan 25, 2009 | 09:15 PM
rsdjcarter's Avatar
rsdjcarter
Congrats! Good job on the Pickle. Told you not to loose faith. I had a feeling it was something just overlooked. Hope the wife has a little patience now.
Old Jan 25, 2009 | 09:55 PM
camperspecial65
drop me a pic of the carb...on the front left ear where the mounting nut is, there will be a code if theres no metal tag on top...snap a pic of the carb stuff and send my way...I got more carbs then I can shake a stick at...
The truck originally was a manual choke btw...
- cs65
Old Jan 26, 2009 | 01:30 AM
WA-SuperPickle
Thanks guys, I'll send pics of the carb tomorrow, if all goes well.
As for the fuel filter(s) I replced them before I tried to fire it up. Replaced both the canister on the fuel pump AND the in-line filter; replaced it w/ a clear one to see if fuel was flowing to the carb.
Added some "Heet" fuel additive to remove water from the fuel and line, also of note - no fuel leaking. I thought I had a bad fuel line, but the left saddle was leaking out through the neck. I tightened down the cap - problem solved.
Here's a weird one, the left tank is almost full! I switched over to it after warming up, and it's burning fine. (?) I drove it around the block again, ready to switch tanks, but it just kept on going strong.
I've also fixed the CB, and found it has a MAP LIGHT! There was no bulb and a piece of napkin stuffed in the socket (?). I put a bulb in and POOF!
I figured out what one of the big red wires on the pos side of the solenoid is... it's a power lead to the inside of the cab for the horn (remote button on the dash), CB, and "the mystery switch". The Sun Super Tach II is toast though. I made sure it was hooked up right, and the connections were good - no go. Say, how do you get to the Speedometer cable behind the speedo? Does it just pop out? Where does it go (from where to where)? I want to see if it's just loose, or broken.
Thanks again.
Old Jan 26, 2009 | 01:34 AM
rsdjcarter's Avatar
rsdjcarter
Your speedo should unscrew from the gauge and it will run through the firewall down to the tranny, atleast that's how it is on my 65
Old Jan 26, 2009 | 11:58 AM
daveengelson
You may want to remove some of the aftermarket accessories, sounds like you have wires going to the dash that could be part of the problem. Have a 65 F100 where prior owner went to the extreme and added accessories I had never heard of, with wires going every which way. Removed all the extra struff, then bought a wiring manual for $7; not the laminated 1 on ebay, found it useless, then over couple weekends or so, gradually took each circuit and either repaired the wires or replaced the harnesses. Found alot of the electrical problems were due to poor ground. Cleaned all the grounding points, added dielectric grease to grounding points and connectors, also added a couple extra grounding straps, and the electrical gremlins eventually went away.
