Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Is Chrysler done?
Old Feb 4, 2009 | 10:13 AM
  #46
tjc transport's Avatar
tjc transport
i ain't rite
somewhere between zero, and minus 500.
ford has already ended it's relations with navistar, and is in the process of releasing it's own engines for the upcoming model year trucks.
Old Feb 4, 2009 | 10:41 AM
  #47
BigDaddy6969's Avatar
BigDaddy6969
Originally Posted by Flying_Dutchman
If Chrysler does go down, what do you guys think the odds are that Ford could pick up Cummins and drop powerjoke?
How f'n sweet would that be?
Old Feb 4, 2009 | 12:24 PM
  #48
quaddriver's Avatar
quaddriver
well ford lost the lawsuit and settled out of court for an undisclosed sum, and navistar entered with nissan who sells trucks in AUS, SA and the African SC by the boatload - all diesel. (plus also nissan wants to purchase the mopar truck line)
what is most worrisome is ford making its own engine. they proved beyond any doubt with the triton that they do not have the facilities to properly test a new powertrain.
Its taken well over 10 years to have a modular engine package that does not come close living up to the reliability of its predecessor and now have a go with a diesel out of the blue - this should effectively kill off any illusion of reliability of its cash cow - the F series. they are practically forcing me at gunpoint to buy my next new truck from chevy.
Unless the mexicans can do better - ford intends on sourcing these motors from mexico.
Old Feb 4, 2009 | 01:13 PM
  #49
BigDaddy6969
Thank God, finally somebody who agrees with me about the modular engine line. While I am a big fan of the V10, I think the 4.2, 4.6, and 5.4 are serious disapointments compared to what is being offered now and what was offered before them by Ford. Give me a 4.9 over a 4.2, the 5.0 over the 4.6 and the 5.8 over the 5.4, ANY FREAKING DAY!
Back to the CTD/Ford topic-Back before my hiatus there was rumor floating around on here that once the Cummins contract expires with Dodge (I believe in 2010, but not positive) that Dodge will be going with a Mercedes diesel. Is that still the case? If it is then WHY THE HELL wouldnt Ford pick up the CTD, they would have a death grip on the 3/4, 1 ton market if they did.
Old Feb 4, 2009 | 02:37 PM
  #50
dkf's Avatar
dkf
The modulars outpower and outlast any stock small block or big block truck engine made by Ford. Modulars will easily last 200k miles. Ford screwed up with the ealier modulars by going to aluminum heads and not adding enough threads and a few little things here and there. The modulars were/are a step in the right direction and were needed to meet emissions standards.
I own a 302 and the 4.6l will run circles around it.
Old Feb 4, 2009 | 03:00 PM
  #51
Lead Head's Avatar
Lead Head
Agreed that the modulars are superior. Especially in bottom end strength.
Chrysler renewed their contract with Cummins, so you can already forget about ford picking them up. I can also think of a few reasons why ford would not pickup the cummins anyways. First and mainly being that it would require a complete redesign of the the superduties to be able to accomidate the engine. That kind of testing and developement costs millions if not billions that ford does not have, espeically since they would have to scrap their own diesel they've been working on for several years now!
Old Feb 4, 2009 | 04:41 PM
  #52
therifleman556's Avatar
therifleman556
You mean motor mounts and a bellhousing? Theres plenty of people who have made this conversion wanting the Ford/Cummins so the interest is there. On the Chrysler minus Cummins topic it would seem completely logical to assume the next Dodge diesels would be Mercedes-Benz powered. A lightweight scaled down version of the MB4000 semi engine would be pretty neat although it would likely end up being a V8.
Old Feb 4, 2009 | 04:44 PM
  #53
quaddriver's Avatar
quaddriver
Originally Posted by dkf
The modulars outpower and outlast any stock small block or big block truck engine made by Ford. Modulars will easily last 200k miles. .
really? how do you know? Is this based on extensive experience of your motor which averages 5-6 years old as compared to our decades old motor?
Old Feb 4, 2009 | 04:47 PM
  #54
quaddriver's Avatar
quaddriver
there are plenty of people who built 'fummins' trucks using the OLD truck design - which had enuf fore/aft room to accomodate an I6 already.
One of the reasons the modular has such limited potential is the squeezed bore spacing to allow the accessory/cam drive to give an overall length slightly larger than the windsors - not 2 cylinders larger.
Old Feb 4, 2009 | 04:53 PM
  #55
BLK94F150's Avatar
BLK94F150
I know it outpowers them. I also can directly compare my 94 5.8 to my 2000 5.4. The 5.4 kills it in power and smoothness.
My 5.4 did melt down due to a gasket failure, but that's pretty uncommon. A friend of mine also had one (2006) fail with an injector stuck open, but I also haven't heard of that much. Even with mine having coolant in the #1 cylinder and blowing the HG, most of the engine wasn't replaced. Just bolts and gaskets as well as trueing the heads. The cylinders were still perfect after 75K.
IMO I'll take a 4.6, 5.4, or 6.8 over a 5.0, 5.8, or 7.5 anyday.
Mike
Old Feb 4, 2009 | 05:06 PM
  #56
quaddriver's Avatar
quaddriver
Mike
so you are 2 for 2 on blown up 5.4s that you know of....
I wonder what a 5.8 would run like with todays engine controls....prolly like a gm 5.3....
Old Feb 4, 2009 | 05:52 PM
  #57
dkf's Avatar
dkf
The modulars have been out for a long time, since the early 90s. The 6.8l is very popular for shuttle service for vans. 350k miles between rebuilds is not uncommon for these engines and the smaller modulars arn't that far off. If you read many of the threads here on FTE you will see lots of guys have modulars with a lot of miles with little troubles. I've had and have the older Ford engines both carbed and EFI and the modulars are better in many ways.
How many modulars have you owned?
By bolting a KB mammoth SC on a stock 05'up mustang 4.6l you can make over 750hp and over 700tq and thats out of 281ci. Yeah I guess the modulars are really limited.
Old Feb 4, 2009 | 06:26 PM
  #58
92f150I6's Avatar
92f150I6
I do like my 5.4, and it is simply more powerful than the 5.8 by a long shot.
IMO, the modulars were turds pre- PI heads, but after that they work well. Are they as good as the competition, i'd say no right now since I have both a 5.4 and a 5.7L hemi powered vehicle, but they are a good motor relyability wise. Other than crappy ignition coils and egr problems, the modulars seem pretty good.
IMO:
4.6/5.4 non PI < 302HO/351W < PI 4.6/5.4 < 3valve mod < 4 valve mod
the regular 302 is a turd, relyable but weak.
the 4.2L V6 is a crap, IMO and is nothing compared to the 4.9.
Old Feb 4, 2009 | 06:29 PM
  #59
BLK94F150's Avatar
BLK94F150
That I know of? Stop putting words in my mouth. That's two out of many that I know of.
I don't know what a 5.8 would run like, but probably not like what a 5.4 would.
Quite honestly, having driven and still driving both 5.8s and 5.4s, you would have to be a fool to prefer the 5.8 over the 5.4 or any other engine from that era including the beloved 4.9. It may have lasted forever, but it was dreadfully slow. In an empty truck, I even liked driving the 4.2 V6 vs the 5.8.
I'll also agree that the mod engines offered today are in thier twilight. The competition has 1/2 ton engines putting out more HP and almost as much torque as the 3 valve 6.8.
I friggin hate when people take one quote and say, "HA!, that totally proves my point with this one line here".
Mike
Old Feb 4, 2009 | 07:12 PM
  #60
quaddriver's Avatar
quaddriver
exactly none. the windsors have not decided to die yet.
its a good thing they are not beter in many ways...
