basic noob questions
Old Jan 24, 2009 | 12:41 AM
primetime347's Avatar
primetime347
first off I searched as much as I could and im still lost, first question is wheel offset, I am looking to purchase some cheap black wheels to freshen up the look of the truck I was looking at these(check the link). Would these have the correct offset and work with some 31x10.50's or some 32x11.50's?next is I want to put on a leveling kit I see some using a 1.5" in front spring and some using a 2" one preferred over the other? would I need extended radius arms? sorry for the noob questions!
Wheel Details - Discount Tire
Old Jan 24, 2009 | 01:50 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I am not sure about the wheel offset but I can tell you that you will not need extended radius arms for use with a leveling kit. Coil spring spacers are another option to look into other than new springs. They are cheap and keep your factory ride quality.
Old Jan 25, 2009 | 11:05 PM
primetime347
next is I want to put on a leveling kit I see some using a 1.5" in front spring and some using a 2" one preferred over the other? would I need extended radius arms.. I searched and some say yes some say no
Old Jan 26, 2009 | 07:42 AM
MatCat58's Avatar
MatCat58
You can get wheels identical to the ones you linked to only made by cragar from jeg's for 41 bucks a piece. The offset is +4 if i remember right, its whatever the ones with the ford bolt pattern are.
Dcope17
All Things Towing
Dec 13, 2014 07:10 PM
vczar1
Dec 12, 2012 10:24 PM
bobby_rogers
Jan 12, 2012 08:24 PM
4inchlovin
Jul 7, 2010 01:19 PM
JORYLEE76
Feb 11, 2008 10:30 PM
