Sponsored by: Real Truck
EEC Bolts
Old Jan 23, 2009 | 07:41 PM
SpectreZ91's Avatar
SpectreZ91
EEC Bolts
I'm missing the bolts that hold my EEC in place. Can someone tell me what they are so I can replace them? Stupid PO took them out and didn't put em back in and now the EEC moves around and causes the truck to die..
Old Jan 23, 2009 | 08:08 PM
ReAX's Avatar
ReAX
I think they are all 10mm head. I would guess 8mm x 10mm. The three are cad plated, but zinc'd or SS would be fine.
Old Jan 24, 2009 | 08:33 AM
SpectreZ91's Avatar
SpectreZ91
Now is there a cover that goes over the EEC? I was in there looking and saw the EEC mounted to a plate but that plate was not mounted to anything and is able to move around.
Old Jan 24, 2009 | 11:56 AM
ReAX's Avatar
ReAX
The PCM box is mounted to bracket, then the bracket gets three bolts to the body. I think it was two top and one bottom. If you unscrew the 10mm from the center of the 101 pin connector (under the hood) you can remove the PCM and bracket to get a better look.
