Battery light...
Old Jan 23, 2009 | 05:23 PM
Baja16's Avatar
Baja16
Battery light...
I've got a 96' F-250 with a 351W and recently my battry light has been comin on. It first it would just flicker for a few seconds then go out, but now it comes on for a minute or to then goes out. I've only noticed it at night with the highlights on (but when i turn them off the light stays lit). The volt gauge on the dash reads were it always has (about 2/3rds up the scale) and never moves when its out or lit. The alternator was replaced a year ago, dont know the age of the battery though. Today before i left work i put the volt meter on the battery while running and it read 14.42 volts and was pretty steady when i reved it up. I checked the battery connections (fine), the only thing i noticed is the starter motor and the connections down there are pretty skechy...
Does any thing else cause the light to come on, I dont think im low on voltage. The truck runs fine. Could their be a code stored in the computer that could help me out... Open to any suggestions and ideas
Old Jan 23, 2009 | 05:53 PM
BigBlueOx's Avatar
BigBlueOx
its sounds like the signal wire on the Alt. has a bad connection. Or somewhere between the Alt. and gauge.
Old Jan 26, 2009 | 10:21 AM
Baja16's Avatar
Baja16
Update:
well i checked and cleaned the conncetions on the alternator and the light hasn't come on since... Must have been that single wire, thanks BigBlueOx!!
