@&&*(%##$!#@! Thermostat housing
R & R Thermostat w/203 and now I cant get it to seal. Put the o-ring in place, put the bolts in holes, started bolts and then slowly dropped the housing, with a bead of orange Permatex, onto the o-ring and tightened. Still leaks Did I just get out of bed on the wrong side this week?
BTW/all the surfaces were clean and smooth.
Went back to the old neck but this time followed directions .. make sure the surfaces are completely dry. Then used a bit of RTV (gray) I think .. on the seal itself and put it on pump housing. Let it set up for 30 min or so then like you started bolts together and slowly tightened all three so no one bolt could deform the housing.
Worked for me .. no more leaks
And I thought I was the only one...I posted just a couple nights ago when I installed my 203 and had the same troubles.
I fixed mine last night with (another) new neck. I don't think that was the problem though as it looks like the o-ring had slipped out of place. I found that when using RTV the o-ring likes to stick to the water neck and it's very easy to get it out of place.
on
1 Post
New pump, old neck, 203 stat, another new seal + rtv = no leak
Not a lot of rtv though, just as if you were lubing an o-ring. That's my story and I'm sticking to it. In reality though I probably just purchased a neck with bad flange although it look OK to me. Did not try the glass test. I still have the new neck so I'll check that out.
New pump, new neck, new 203 stat, new seal = leaked
Not one left the factory with RTV. Hmmmm.
The 7.3 in the as built T444E does not have this leak problem. Hmmmm.
Bad installs? Cheap replacement parts? Ford application thing?
Granted the oem neck is a stamped part and press fit with 3 tack welds.
With just the gasket sometimes its tuff to remove the neck after a year.
I hate RTV. You installed it to seal the t-stat but down the road you find
it in the oil cooler.
Bill
