93 glow plug controller question
Old Jan 23, 2009 | 10:03 AM
RRranch's Avatar
RRranch
My son just got a 93 f-250 7.3 liter non turbo truck and I've been doing a lot of work on it. I have it running good now after rebuilding the alternator, replacing the batteries, new injector return lines and t fittings.
Anyway, It's been a while since I worked at Ford and I can't remember this one. When we start it, the glow plug controller clicks on and off after the initial warm up cycle for about 1o seconds. Is that normal? All the glow plugs test good and it starts fine but It's annoying with that thing clicking like that.
I'm about to go start rebuilding the E40D in it next for him but I want to make sure I have everything under the hood right first.
Thanks.
Old Jan 23, 2009 | 11:03 AM
farmert's Avatar
farmert
Yes it is normal for the glowplug relay to cycle after startup. It is called afterglow to help the cold engine to stay running.
Old Jan 23, 2009 | 04:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
RRranch,
Welcome to FTE and the IDI diesel forum.
As well as reduce the smoke from a cold engine.
Old Jan 23, 2009 | 07:29 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like you are doing well with the work you have done.
Welcome to the boards!
