turbo questions
Old Jan 22, 2009 | 10:40 PM
vwgtivr's Avatar
vwgtivr
turbo questions
I bought the upgraded turbo wheel for my 2001 f-350 and I'm planning on installing it soon. While I have the turbo off, I want to go through and clean it thoroughly. The only write up I have been able to to find is for the 2003 and up 6.0.
My question is whether or not the 7.3 has the same turbo with the variable vanes or not.
Also, while the turbo is off, what else should I do? Work on the ebpv? Port and polish the intake "Y" pipe? Any thing else I should do?
Old Jan 22, 2009 | 10:55 PM
87 F-150 I6's Avatar
87 F-150 I6
The 7.3L turbo is not a VV unit. I would replace the o-rings on the turbo and the pedestal as the leak once old. You can take the foil off the hot pipe and do the CCV mod while your at it, change the air filter to the 6637 if you haven't already. Changing out the up pips to bellowed units would also be a good idea. Installing the stainless steel high presser cross over line would also be good as the turbo is not in the way. As far as cleaning the turbo somebody with more knowledge will chime in.
Old Jan 22, 2009 | 11:04 PM
vwgtivr's Avatar
vwgtivr
what would taking the foil off of the hot pipe do for me?
Old Jan 22, 2009 | 11:13 PM
CSIPSD's Avatar
CSIPSD
Nothing other then make more noise...
Just put the wheel on and be done. Unless your up pipes are leaking you will not see a bit of differance from doing anything.
Old Jan 22, 2009 | 11:17 PM
87 F-150 I6
Most people love that turbo sound, taking of the foil makes it louder.
