88 ranger
Old Jan 22, 2009 | 02:18 PM
parkermrk's Avatar
parkermrk
88 ranger
I have an 88 Ford Ranger that wasn''t running when I bought it. The problem is that the fuel pump won't come on. The signal that turns the relay on is not going low when I turn on the ignition switch. I can force it low with by grounding it and the truck will start and run. Is there a sensor that interlocks the fuel pump circuit? The EEC relay (whatever that is) is the same relay as the fuel pump and it''s not turning on either. What am I missing?
Old Jan 22, 2009 | 05:05 PM
mrshorty's Avatar
mrshorty
Fuel pump relay is closed by the PCM, which gets its power from the EEC relay. If I were in your shoes, I'd focus on why the EEC relay isn't closing (bad wiring, bad ignition switch, bad EEC relay).
Old Jan 22, 2009 | 09:10 PM
drb1956's Avatar
drb1956
I would look at the ignition switch like mrshorty says-its down the steering column..look to see if its burnt or discolored..also, push down on your entire power dist. box when you have it open to make sure that all the relays are seated properly, and the box hasn't been lifted up of the board, and the relays don't make contact....
Old Jan 23, 2009 | 01:12 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
I just had this problem with my '85 Ranger about 4 months ago, and it turned out to be a faulty ignition switch.
bsparks72
1997 - 2003 F150
May 21, 2010 07:18 AM
parkermrk
Jan 22, 2009 05:36 PM
ranger7998
15
Apr 15, 2007 03:56 PM
Ranger88
4 Cylinder Engines
Dec 1, 2005 01:30 PM
BRX98GT
Sep 10, 2004 08:38 PM
