which axle do I have
Old Jan 21, 2009 | 09:13 PM
jab55's Avatar
jab55
I have an 88 f-350 how can I tell what axle I have. The cover has ten bolts and the cover is oval.
Old Jan 21, 2009 | 09:21 PM
bwoldschool65's Avatar
bwoldschool65
theres a sticker in the door jamb with your axle code and other codes.....forgot what its called
Old Jan 21, 2009 | 10:47 PM
atillett's Avatar
atillett
dana 60 if it a soilid axle.
Old Jan 21, 2009 | 10:50 PM
atillett's Avatar
atillett
by the way you dont need it. I will gladly take it away for you....I will trade you my dana 44 twin traction...It is a much better axle.........Shees i am just joking the 60 is a highly coveted axle..........I would do any thing to have one.........
Old Jan 22, 2009 | 01:14 AM
colemanw's Avatar
colemanw
it could be a sterling 10.25
Old Jan 22, 2009 | 08:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you are talking about the front rear, it is a dana 60
if you are talking the rear rear, it is a sterling 10.25.
Old Jan 22, 2009 | 08:35 AM
jab55's Avatar
jab55
The reason I am asking is because the set of Flowtech headers I am looking to buy say will not fit if it has a dana 60 in the front.
Old Jan 22, 2009 | 01:10 PM
str8dogg's Avatar
str8dogg
for an 89 F150 what would the axle code of 19 represent?
Old Jan 22, 2009 | 01:15 PM
andym's Avatar
andym
You have a Dana 60 in front for sure.
An 8.8" axle with 3.55 gears and an open carrier.
Old Jan 22, 2009 | 02:09 PM
str8dogg's Avatar
str8dogg
So I have a 3.55 ratio, cool. Since I am no mechanic, what would be the difference in the 3.08, 3.55, 4.10. My owners manual gives these options, so I have assumed 3.55 since it was highlighted in the manual by the previous owner. I was told that the ratio information was either posted on the tranny, which it isn't or on a tag on the rearend differential. I found the tag on the rearend and here are the numbers
S817P
3l55 8 8 9D03
Do these numbers also give way to the ratio? Finally, when requesting a tranny the ratio is asked, how would that effect the mechanics. Again, no mechanic, so forgive my ignorance.
Old Jan 22, 2009 | 02:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bwoldschool65
there's a sticker in the door jamb with your axle code and other codes.....forgot what its called.
The AXLE code will be found on the white Certification Label.
If the AXLE code begins with a letter = Limited Slip / If with a number = no limited Slip.
Old Jan 22, 2009 | 02:57 PM
alxsnmr's Avatar
alxsnmr
S817P
3l55 8 8 9D03
Isnt the 3L55 a limited slip 3.55 ratio or did he misread the something as an L on the axle tag?
Old Jan 22, 2009 | 03:03 PM
NumberDummy
S817P
3l55 8 8 9D03
3L55 = 3.55-1 with Limited Slip / 8.8 Rear Axle
Ford used a capital L to denote Limited Slip.
Typing a small l is confusing, as it looks like the roman numeral 1.
Old Jan 22, 2009 | 03:13 PM
str8dogg's Avatar
str8dogg
Correct I did mistype, it was the "I" supposed to be an "L". So that question is answered. Now what is the difference and how would it affect??
Old Jan 22, 2009 | 03:17 PM
andym's Avatar
andym
S817P
3l55 8 8 9D03
Yes, the '3 55' is the gear ratio. The '8 8' after it is the diameter of the ring gear. The other numbers are build numbers and other less interesting stuff.
What the number 3.55:1 means is that for every one rotation of the pinion (what the driveshaft is connected to) the axles rotate 3.55 times. If you physically count the number of teeth on the ring gear and divide it by the number of teeth on the pinion gear you will get 3.55. That's where the number comes from.
The larger the number, the lower the gears are said to be. Most F-150's had 3.08 or 3.55 gears. The lower the gear, the more perceived power the truck has, but the higher the engine has to spin. So there is a trade-off between power and fuel economy. However, sometimes a change to lower gears can increase mileage because the engine doesn't have to downshift in order to climb a hill like it did with the higher gears.
Larger tires also have the same effect as lower gears. With bigger tires your engine won't spin as fast, but you will have less power. This is why larger tires are often done at the same time as a gear change.
Transmissions don't have anything to do with gear ratios in axles. Who is asking for gear ratio when "requesting" a tranny?
