gauge problems
Old Jan 21, 2009 | 06:59 PM
hazy's Avatar
hazy
gauge problems
hey everyone, i just signed up after my 1976 f150 was purchased. i got it running but the gauges don't work. i tried grounding the wires but the gauges didn't sweep. im not sure it is getting any power. i have an old old wiring diagram but there are 4 different versions and is a mess. any ideas would be awesome. thanks.
Old Jan 21, 2009 | 07:08 PM
jcduerr's Avatar
jcduerr
do you have a wire tester or a ohm meter to check if they are getting power
Old Jan 21, 2009 | 07:39 PM
hazy's Avatar
hazy
im at a shop i got everything. :-) but i don't know for sure what wire is suppose to have power to the gauges.
Old Jan 21, 2009 | 08:41 PM
jcduerr's Avatar
jcduerr
check grounds and get a chiltons or haynes and trace wire back and chect for voltage
EDIT*** check around here https://www.ford-trucks.com/forums/member.php?u=14542 see if there is any thing there or http://{M} i l 1 o n dot clubfte dot com/
Old Jan 21, 2009 | 10:40 PM
hazy's Avatar
hazy
didn't see anything in there. but ill look in my old mitchel book.
Old Jan 22, 2009 | 11:02 AM
73FOMO's Avatar
73FOMO
If I am not mistaken it is a purple wire with the printing ballast resistor "do not cut" that powers the gauges. Just take out the gauge pod and look on the back at the printed circuit and trace the guage power to the color of wire on the connector. I also pretty sure tracing back the ground for the guages you will find a black wire(s) in the connector. So there you go, your power incoming (purple) and ground (black), but double check the circuit as I am going off memory from my '73 panel.
Old Jan 22, 2009 | 11:54 AM
hazy's Avatar
hazy
thanks i saw that purple and i will check it
