need help badly
Old Jan 21, 2009 | 01:13 PM
bfford's Avatar
bfford
need help badly
I drive an 05 f250 w/5.4 my wife drives a 2000 expedition with 5.4 on the wifes truck it has developed a probem after the motor warms up and it is extremely cold out when you pull up to a traffic light it wants to stall unless you pop it into neutral and keep your foot on the gas i have already replaced the iacv and it is throwing system lean on bank 1 and 2 any ideas
Old Jan 21, 2009 | 01:49 PM
pdqford's Avatar
pdqford
Vacuum leak - prolly in the PCV hose elbow.
Old Jan 21, 2009 | 02:06 PM
bfford's Avatar
bfford
checked all that last night, what about leak around intake? I have been told this is common, i am lost and dont really like throwing parts at it.
Old Jan 21, 2009 | 04:10 PM
pdqford's Avatar
pdqford
Since you have both the P0171 and P0174, both banks are lean, so the leak would have to be something that would effect both banks. Perhaps a leak after the MAF and before the TB? Dirty MAF? If the intake is the cause, both sides would have to be leaking. Is your dip stick fully seated? EGR valve not seating completely? Exhaust leak upstream from the O2 sensors?
Old Jan 22, 2009 | 07:18 AM
bfford's Avatar
bfford
I think I found it last night, their is a small hole in the vaccuum line going to the egr valve
Old Jan 22, 2009 | 12:13 PM
pdqford's Avatar
pdqford
Thank you for posting your solution.
