cab clearence light delete?
Old Jan 20, 2009 | 06:08 PM
smoky_diesel's Avatar
smoky_diesel
So the PO put factory style amber cab lights on. I would rather not have them, especially now that I have got rid of the amber turn lenses.
How big is the hole for the wires?
I have looked on flee-bay for replacement options but did not see anything that I really liked such as clear, GM or dodge style.
I though about fabricating some sort of low profile set up. possibly an acrylic plastic plate with some blind holes for LEDs. The edges of acrylic really shine with incident light, just like your factory gauge needles. make em' a similar shape to the existing lights, cut some gaskets and the total hight is about 3/8". comments?
Old Jan 20, 2009 | 06:24 PM
bdrummonds's Avatar
bdrummonds
Main hole size is 5/8, and then there is a screw hole on each side of the big hole, 1/4" maybe.
it looks like this
oOo oOo oOo oOo oOo
sounds like bondo to the rescue, then sand prime and paint.
I do like the idea of the glowing acrylic, just might be hard to get that big of a chunk of acrylic whittled down.
Old Jan 20, 2009 | 06:26 PM
jdecker88's Avatar
jdecker88
If you get rid of them let me know I'll take them off of your hands before they clutter up the garage. Just don't cut the factory harness all to pieces.
Old Jan 20, 2009 | 06:32 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I know they make smoked ones, as for clear or what not, not sure. I am sure some folks will chime in here.
Old Jan 20, 2009 | 06:36 PM
SpringerPop's Avatar
SpringerPop
I bought clear replacement lenses for mine.
Perfect duplicates of the factory lenses, except for color. I use amber bulbs.
Ebay, couple of years ago. Same vendor as the smoked ones Mike mentioned.
Pop
Old Jan 20, 2009 | 07:14 PM
Ponyboychris's Avatar
Ponyboychris
Old Jan 20, 2009 | 08:29 PM
fxstbchopper's Avatar
fxstbchopper
I have Recon LED lights with clear lenses on my truck. My hole for the wiring is 7/8".
Old Jan 20, 2009 | 08:31 PM
bigsteve1969's Avatar
bigsteve1969
usually its folks wanting them put on instead of taken off.. like brandon said guess its bondo sand and paint
Old Jan 20, 2009 | 09:46 PM
megawatt00's Avatar
megawatt00
Just what I was going to say Tracy. Recon has a ton of stuff like that
Old Jan 20, 2009 | 10:08 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I got these clear lens-only replacements from Recon:
Recon Accessories: Part # 264142CL - CLEAR Cab Lights Ford 99-09
Here's a pic of them on my truck:
Old Jan 20, 2009 | 10:16 PM
SpringerPop
Old Jan 20, 2009 | 11:26 PM
RussB's Avatar
RussB
If you're going to go to that extent....... don't use bondo ! Just weld up the hole !! put a thin coating of bondo.... and then sand and paint !! Just my opinion !!! I'd just put the clear lenses on there like others have done and it should be good !!
Old Jan 21, 2009 | 08:13 AM
bigsteve1969
depends on how good the welder is... for sure not a first time job. ive got the smoked lens and they kinda blend in with the black roof on mine..
Old Jan 21, 2009 | 08:52 AM
jeff7825's Avatar
jeff7825
Looks like a body shop is in your future, unless your skilled at paint and bodywork.
Old Jan 21, 2009 | 11:08 AM
smoky_diesel
body work is one of my least favorite things to do. I'd rather pull a transmission. welding 5, 0.625" holes closed doesn't sound like fun either. I bet the roof metal is paper thin too.
The clear lenses are cheaper than just the paint. maybe I will try to make one acrylic lens and go from there.
thanks for the info and insite
