Testing an O2 sensor???
Old Jan 20, 2009 | 05:43 PM
C Holmes's Avatar
C Holmes
Hi, I have an 88 302 F-150 and would like to know if anyone knows how to test an o2 sensor? I have a test procedure here but seems a bit confusing to me. I have 12v to the sensor lead and a good ground. The procedure says to probe the other lead with the engine warm to see if I can get a volt reading of 0.45 + or - and for it to change rapidly. Well mine reads 0.18 and it only changes from 0.18 to 0.19 and up and down. I can rev the engine up and down and only get a slight voltage drop or raise but it is consistent at 0.18 to 0.19 or so. How much should I get? I have also disconnected vacuum and same results. Any suggestions? Is it fried or what? Any help appreciated. Thanks in advance.
Old Jan 20, 2009 | 06:05 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Has the truck thrown any codes relating to the O2 sensor? If it has not, the O2 sensor is probably still good.
Old Jan 20, 2009 | 06:32 PM
C Holmes's Avatar
C Holmes
No it has not, But it is quite hard on fuel. I also should mention I can unplug it and it does not seem to make a difference in the running of it at all. I will check codes again to make sure.
Old Jan 20, 2009 | 07:51 PM
1994 F250: 351, C6
Even though it does not make a difference in how it runs, the Check Engine Light will come on when it is unplugged.
As far as being hard of fuel, how long has it been since the plugs, wires, cap, and rotor were changed. This is the first place I go when mileage is crappy and there are no Check Engine Light problems.
Old Jan 20, 2009 | 08:28 PM
deeznuts822's Avatar
deeznuts822
USUALLY,at least what i have learned with my ford truck is that if the o2 sensor doesnt read what its supposed to the check engine light will either flicker after ten min of driving or will just stay on. I tried testing it but when i just went out and bought a new one all problems were solved. But i had code 41
Old Jan 20, 2009 | 09:33 PM
Conanski's Avatar
Conanski
On a motor that's running right with all sensors in range, the O2 sensor only switches when the A/F ratio is at 14.7:1. The problem with testing it in your truck is that if the rich condition is not being caused by a bad O2 sensor, if it's something else that's not under computer control like a stuck or leaking fuel pressure regulator, then the motor will always be rich because the computer doesn't have enough fuel trim adjustment, and the O2 sensor won't switch like it's supposed to. These narrowband O2 sensors switch back and forth between 0 and 1 volt.. which in practice is often more like 0.3v to 0.7v with 0.45v equal to 14.7:1.
Old Jan 21, 2009 | 04:30 AM
C Holmes's Avatar
C Holmes
So just change it and be done with it?
charles5000
Jan 28, 2014 07:31 AM
frdsks
1983 - 2012 Ranger & B-Series
May 4, 2013 08:55 AM
gearhead351
Nov 2, 2007 06:59 PM
80broncoman
Aug 31, 2007 09:33 PM
slam^50
New Member Introductions
Jun 13, 2006 05:10 AM
