Blower motor relay on a 1998 E 350 Super Duty
Relay location
My 1999 manual shows that it is in the "H" position. Upper right hand corner of the power relay box when looking at the front of the van. All of ther relays there are the same. You should just be able to swap them to see if one is bad. Mine was good. I think that its my blower motor that is bad.
Relay
Thanks,
I found the problem, it was the switch that had gotten hot and burnt up. Mine still worked on low and med, but no high speed. On mine, according to the schematic, if the motor runs at any speed then the relay is ok. That is because the the relay circuit supplies the hot or + power to the motor.
Chuck
P.S.
I have the schematic of the circuit if you need it... Keep in mind mine is 1998 E 350.
Chuck
P.S.
jayro88
16
02-28-2015 12:06 AM
jayro88
02-26-2015 07:44 AM
MikeBlansfield
10-16-2014 06:02 AM
