Not so much. The black smoke from the diesel is incomplete combustion. I don't think gasoline will produce nearly as dark exhaust from running rich. You can get one of those kits from auto lock which injects a smoke chemical (probably dirty/wet kerosene) into the tail pipe.
I did not think it would be anything like a diesel. I think it would put out just enough to see and not enough that people would just think there was something wrong. I would also think it would be easier for a diesel to put out some since they us heat and pressure unlike gas witch uses spark.
I dont want to do it I was just wounding if you could even do it. like i said before i think it would be enough smoke to make it look like something was wrong not like i have a lot of power.
I have a 99 5.4 and one of my friends told me that i can get it tuned to put out black smoke like a powerstroke. Is this true?
It is true. the smoke wont be black it will be more of a gray color, I dont know if he stock injectors will richen up the mix enough to make a huge cloud but it can be done, With my KB at WOT it runs a FAT AFR of 10.2 and when im screaming down the road there is a cloud of unburnt fuel coming out of the duals in the back, looks cool but not good for making power, KB does this so they can advance the timing and not run into detonation.
