heat
Old Jan 20, 2009 | 08:46 AM
greenterror's Avatar
greenterror
Unhappy heat
i started my truck put the dial to heat and turned dial for speed,when i did that not even cold air nothing is comming out.is this the blend door? 02 expy 48,000 5.4 v8
Old Jan 20, 2009 | 10:46 AM
c_hohensee's Avatar
c_hohensee
I assume we are talking about manual HVAC here. Can you hear the blower running? If not, try setting the fan speed to a different speed and see if it works. If this starts the fan then you have a bad resistor If you cannot hear the blower at any speed I would check fuses. The blend door just controls the mix of air coming through from the heater core. Try this stuff and let us know and we can go from there.
