6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Warranty what's the line??
Old 01-20-2009, 12:58 AM
FX$'s Avatar
FX$
FX$ is offline
08' F250 FX4 4X4 PSD
What is the line to cross that voids the warranty?
If i change out the air filter to a banks RAM Air will that void the warranty??
If i put a banks exhaust system on will that void the warranty??
( i could but the air regen perforations on the pipe just befor the tip? )
what if i put in a turbonetics intercooler?? warranty??
Thanks for your input in advance
Old 01-20-2009, 03:47 AM
senix's Avatar
senix
senix is offline
Received 1,427 Likes on 1,020 Posts
I would speak with the local dealer and get there input. I would think that the air filter and exhaust would be ok as long as you don't touch the emissions stuff like the DPF. But to be sure I would speak with them.
Old 01-20-2009, 03:49 AM
ctownson's Avatar
ctownson
ctownson is offline
there have been many similar discussions and feedback on this topic. general consensus seems to be that you have to be very careful in this area due to all the DPF and emissions related equipment. I would check with your local dealer also. I bit the bullet and purchased the extended warranty with my f250. So far, I am very pleased with the truck!
Old 01-20-2009, 06:27 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
Angry
I purchased the xtended warranty also. I get 200,000 miles to blow it up.
I asked my dealer's service manager's point blank, What can I do to my truck to get better performance/fuel mileage?
They both looked at me and said "absolutely nothing can be modified to the engine and it's components".
I asked about the chip, engine programmers, exhaust systems and they just said no. The only thing they told me to do is I can add cetane boost to the fuel and I can put that Z-Max stuff in the oil. That's it.
Just for your information, this is my experience.
Old 01-20-2009, 08:26 AM
caprang's Avatar
caprang
caprang is offline
Ford has really cracked down and is adopting a no tolerance policy. Its subjective to the dealer you go to and the type of problems you have. Some dealers will overlook a programmer while others will refuse work because of bigger tires. The ultimate factor is whether Ford will pay them for the repairs. For instance, Dealer X has no issue with your programmer when your power window motor fails. Maybe even ok with it if you lose an injector. But one day the engine blows. If dealer X sends your old engine back to Ford (as they are required to do) and they see the marks on the pistons proving you had non-oem tuning, then Ford doesnt pay dealer X for the repair.
Old 01-22-2009, 07:31 PM
pyro2nite's Avatar
pyro2nite
pyro2nite is offline
I think that pretty much it in a nut shell. It's all about what the dealer feels comfortable with. Mine said they will say nothing unless asked by Ford. I would take it to the dealer and be up front with them and see what they say. Good luck
GreenballsFX4
6.7L Power Stroke Diesel
04-25-2011 07:11 PM
Still Smoking
2004 - 2008 F150
07-03-2008 06:00 AM
Wrinkleface
05-05-2007 01:13 AM
homer4.2
2004 - 2008 F150
04-19-2005 08:58 AM
EK33
2004 - 2008 F150
25
07-10-2004 03:25 PM
Quick Reply: Warranty what's the line??
