GRRR - IAC valve
Old Jan 19, 2009 | 11:41 PM
Icefan71's Avatar
Icefan71
GRRR - IAC valve
After reading this forum and experiencing stalling problems, I decided to change the IAC valve on my 98 EB 5.4. Its a real pain in the @$$ to get out. I'm having trouble getting to the bottom screw. I decided to take another crack at it tomorrow. Also, I got the top scew out and then proceeded to drop it. Its somewhere on the manifold hiding. Just wanted to vent, lol
Old Jan 20, 2009 | 05:30 AM
Gevans17's Avatar
Gevans17
I feel your pain Icefan! good luck.
Old Jan 20, 2009 | 02:28 PM
Frat-man-du's Avatar
Frat-man-du
Always the case! I have used compressed air (not from a wimpy can but air compressor - and don't forget to wear goggles) and see if you can blast it out from underneath. Be careful if the pressure is too high it can damage brittle little rubber hoses...
No worries you will have it done by the weekend!
Old Jan 21, 2009 | 07:32 AM
Modified 99's Avatar
Modified 99
I have removed mine a couple times now. My 99 Exp has 170K+. Be CALM and take your time. I clean mine with Amsoil Power Foam and acetone. I do this as a preventive maintenance item, not waiting for it to start acting up.
You may be able to retrieve the screw with a magnet.
mdgaf
Bronco II
Apr 16, 2013 09:01 PM
JFlom77
Feb 23, 2010 01:00 AM
dkelley2000
2004 - 2008 F150
Oct 15, 2008 12:53 PM
TheMonkey
Sep 6, 2008 02:23 PM
ghkramer
Modular V10 (6.8l)
Dec 5, 2005 12:58 AM
