diff troubles
Old Jan 19, 2009 | 11:40 PM
dragonmaster093's Avatar
dragonmaster093
diff troubles
well I found out what diff I have in the front its a dana 44 hd found out the hard way. Wheel bearing went out on drivers side and broke axle shaft and spindle problem I now have is I cant find a spindles. Found a diff out of a 75 but if I read right one here it wont work because of the drum brakes and axles wont work according to hollanders the axles are 76-77 specific. Dana dont make them and everyone in a 100 mile radious has no spindles. The spindles have five bolt mounting. any body got any with the nuts?????????? HELP!!!!!!!!!!!!
Old Jan 20, 2009 | 02:25 AM
lostinfords's Avatar
lostinfords
100 miles of where?? cancel that I found out!!
Old Jan 20, 2009 | 05:00 PM
bartn98's Avatar
bartn98
where are youlocated? i have a low pinion hd dana 44 out of a 77 highboy for sale if your interested pm me
Old Jan 25, 2009 | 10:48 PM
dragonmaster093
latest update got spindle cant find right outer shaft its 11 5/8 inches long and only ones i can buy new are 10.66 inches long
Old Jan 26, 2009 | 01:11 AM
Dirt racer's Avatar
Dirt racer
Bronco graveyard.com might have them, check it out. I had some off my 75 F-100 4x4, but thew them out with the scap metal when I converted to disc brakes from wild horses bronco site. Just another idea.
Old Jan 26, 2009 | 01:33 AM
dragonmaster093
thanks ill check it out. also looking at ord is there a differense in 1/2 ton and 3/4 ton stub shafts or in gm and ford dana 44s of same era
Old Jan 26, 2009 | 01:50 AM
Dirt racer's Avatar
Dirt racer
Don't forget about dodge too. They all used the dana 44 front diff. Not sure what the differences are though. Good Luck.
Old Jan 26, 2009 | 09:27 AM
maneyup's Avatar
maneyup
the 3/4 dana44 uses larger stub shafts than the common 1/2 dana44 i dont remember the exact size difference but the shafts and spindles are larger. i havent converted one yet but i do know someone who has so it is possible.
Old Jan 27, 2009 | 10:39 AM
dragonmaster093
Another up date got my truck back but idiots at shop drug it around with a bob cat and now t case growls abd won't go to neutral or 4 low and 4 high is basicaly 2 high
