need more power
im looking for the most bang for the buck performance mods for my truck. its a 91 f150 lariat ext cab 2wd w/ a 302. i dont realy care about the hp numbers just the seat of the pants feel. i just want to have a fun truck to drive around in. as far as budget goes its low bux but im saveing and not cheaping out. i want it done the right way the 1st time. it will just take longer doing it twice. so far it only has a k&n filter, stock replacement not the intake. and it has a throtle body spacer. both done by old owner so im not sure if that did anything or not. it also has a posi, not sure if its factory or not but ive never had it break lose and im always doing burnouts.
thanks for the help
i would throw on long tube headers lose the cat and duel exhaust, if you are able pick up some gt 40 heads throw a quick port job on them and have them milled to bump up the compression a bit (AFR heads will be better) and i ditched my crappy speed density fuel injection system for a edelbrock air gap manifold and a carb with an HEI dissy with a mallory coil (not in the picture) and toss a fat roller cam in there it's pretty simple to convert your block to a roller block it already has the bosses you just drill them out and toss on that spider looking retainer thingie
you should also do gears and a you can use a real high stall converter with the aod because it locks up the converter in 3rd i have a 3500 on my truck and it's my daily driver makes for a fun ride probably runs mid 14s now but i am going to steal the NOS cheater system off my t-bird and throw it on my truck for a weekend and head down to the track and see if i can get 13s or 12s with out blowing it up lol but if i do i can get another shortblock for $300 out of a junk yard, that's what i love about these motors
throttle body spacer was a waste of time and money.
keep doing burn outs and you will be worrying about repairing things not getting more performance.
start with a good tuneup with quality parts.
no bosch platinums.
tricks are for kids.
for real air flow in and out of the motor is a start. so is spark. a programer never hurt either.
