Bogging down
Old Jan 19, 2009 | 07:31 PM
Cap'nDewie's Avatar
Cap'nDewie
Bogging down
I have a 1990 Ford (obviously) F 150 2WD XLT Lariat reg cab LB
Anyways, i just bought the truck about 2 months ago. Haven't really gotten a chance to drive it, so i took it on a 2 and a half hour road trip i needed to go on just to see how it would perform.
Something i noticed is that when accelerating too much, or just when in higher speeds (around 60 - 70 mph) It bogs down and kinda shakes as if it's not getting either enough gas, or air. I checked the air filter and its brand new. So I'm not sure what kind of problem i have. The truck runs fine, its just annoying when you can't get the full performance out of it when you should.
Any tips? should i check the fuel injector for air flow problems or should i drop the tank and check out the pump or..? is there possibly a fuel filter that might be clogged.
I haven't tried to see if the problem is consistent in the rear gas tank, I've not had enough money to put gas in it yet.
Old Jan 19, 2009 | 07:55 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I would replace the fuel filter and check for a clogged cat.
Old Jan 19, 2009 | 07:57 PM
Cap'nDewie's Avatar
Cap'nDewie
clogged cat?
And where is the fuel filter? is it inside the tank or is it somewhere in the exterior fuel line?
Old Jan 19, 2009 | 08:15 PM
1994 F250: 351, C6
Catalytic converters can cause loss of power when they get clogged up. You can often spot a bad cat by hitting it with your hand and listening for rattles, other times they just get clogged up and cause loss of power.
On your 1990, the fuel filter should be along the inside of the driver's side frame rail about halfway down the truck.
Just in case something is weird and your truck has the filter in the location of the '87-'89 trucks it would by the fuel supply pump on the frame rail back by the tank.
Old Jan 19, 2009 | 08:16 PM
1994 F250: 351, C6
Sorry, double post!
Last edited by 1994 F250: 351, C6; Jan 19, 2009 at 08:18 PM. Reason: Double post: Sorry!
Old Jan 19, 2009 | 08:18 PM
Cap'nDewie's Avatar
Cap'nDewie
Alright, thank you very much. I'll give that a try when the snow melts haha
Old Jan 19, 2009 | 08:22 PM
1994 F250: 351, C6
Good luck, have fun in the snow. I did an outdoor oil change on the Explorer at 27 degrees.
Old Jan 19, 2009 | 08:24 PM
Cap'nDewie's Avatar
Cap'nDewie
try shoveling off a foot of snow at -30 wind chill to go to work. haha
Old Jan 19, 2009 | 08:56 PM
1994 F250: 351, C6
That is just plain crappy. We had horrible single digit real temperatures a few feet of snow and high winds from before Christmas until right after the new year. It has been in the low forties most days since the 2nd but the damn snow is still piled up in parking lots and beside the roads.
Old Jan 19, 2009 | 08:57 PM
1994 F250: 351, C6
The winter sucks when you do not have a garage to work in!
Old Mar 10, 2009 | 08:01 PM
mastaplan2k8's Avatar
mastaplan2k8
think the oil change is bad, my buddy had a 87 chevy ( i know, chevy talk in a ford forum ) and the flywheel was bad. His buddy did it outside, replaced flywheel and clutch in below zero weather here in wisconsin over 2 days. Thats dedicated. and he made like 100 bucks. lol
