Initial timing on '89 302
Old Jan 19, 2009 | 07:18 PM
bigcountry1009's Avatar
bigcountry1009
What's the initial timing on an 89 model 302. I'm trying to figure out what total timing is on the motor, but I can't get a clear answer to how to figure out initial timing on a motor that you're not sure of.
Old Jan 20, 2009 | 08:37 PM
393STROKER's Avatar
393STROKER
You have to pull the spout plug from the distributor wiring harness, then set the timing @ 10 BTDC,then put the plug back in
