my 6637
Old Jan 19, 2009 | 07:02 PM
beer boy's Avatar
beer boy
my 6637
theres more pics in my profile.
get everything out o f the way, i hoped to be able to keep the factory intake from the front of the truck because i like its set up.
basically i had a sheet of .050 aluminum that i made the box out of. i used rivets for now to see how i like it. if it goes ok then ill weld it up.
its a tight fit and the aftercooler pipe on this side is touching the intake hose. if this becomes a problem then ill fab a new intake to the turbo.
it gets air form the front factory inlet and now from the fender. so far its great. there is a louder whistle, me likey, and there is a difference in pedal response. i havent done anything with the sensor yet other than let it hang under the master cyl. its fine for now. its as air tight as it needs to be.
also while i was under the hood i installed the led for the glow plug solenoid (theres pics) and i had the chance to use it this past weekend when the outside temp was -22c, without windchill. dam cold... by waiting until the light in the cab went out and then starting, instead of guessing the truck started perfectly.
Old Jan 19, 2009 | 07:10 PM
Ponyboychris's Avatar
Ponyboychris
Looks great. Reps sent.
Old Jan 19, 2009 | 07:13 PM
F350-6's Avatar
F350-6
Nice work. I also like how you got the text in the photos to make things easy to understand. Looks like all your missing is one of these Photo Gallery
Old Jan 19, 2009 | 07:16 PM
hucka1a's Avatar
hucka1a
Looking good.
Old Jan 19, 2009 | 07:22 PM
fxstbchopper's Avatar
fxstbchopper
Good job.. As Chris said all you need now is one of Pete's covers.
Old Jan 19, 2009 | 08:17 PM
megawatt00's Avatar
megawatt00
Looks good! Gotta get a Pete's Cover though.
Old Jan 19, 2009 | 08:19 PM
Adam0331's Avatar
Adam0331
Did a good job.
Old Jan 19, 2009 | 09:15 PM
rblaine9000's Avatar
rblaine9000
nice work on the box
Old Jan 19, 2009 | 09:34 PM
jrf250's Avatar
jrf250
Great job, looks like a factory bought one.
Old Jan 20, 2009 | 12:56 AM
87 F-150 I6's Avatar
87 F-150 I6
looking good, thanks for the great write up!
Old Jan 20, 2009 | 01:24 AM
4inchlovin's Avatar
4inchlovin
Nice job on the box and the write up!
Old Jan 20, 2009 | 08:17 AM
03_PSD's Avatar
03_PSD
nice job on the intake!
Old Jan 20, 2009 | 09:19 AM
jdecker88's Avatar
jdecker88
Very nice cold air box that is a great way to untilize the factory air box.
Old Jan 20, 2009 | 10:19 AM
superduty4x4's Avatar
superduty4x4
Nicely done!
Old Jan 20, 2009 | 10:52 AM
big poppa's Avatar
big poppa
Looks great, Pete,s cover is a must, it will compliment everything you done. Reps sent on the airbox fabrication..
