Help w/ 2003 FX4 Level II Tcase Issues
I have a 2003 Ranger FX4 Level II that I believe has a bad tcase. When I shift into 4wd everything seems to work properly and all 4 tires will spin. The problem is when I accelerate a little harder there is a loud pop from under the truck and the front tires are no longer spinning. I had a friend put it in gear and hold the brakes while pushing the gas pedal. From what I could see is once the front driveline gets to a certain level of torque it seems the chain in the tcase starts jumping teeth on the front output. After it pops, if you keep on the gas a little longer all it does it ratchet inside the tcase. The rear driveshaft will still be under load but the front is just sort of twitching.
What do you think the issue is? Dirty shift motor, or stretched chain/stripped sprocket?
Thanks
PS it is a BW 1354 Electric
Thanks
Thanks wendell, that was what I was thinking as well but just wanted another opinion. I am more of a mechanical tcase guy, so I was a little unsure if a faulty motor might be able to cause my problem. Pretty sure the chain stretched and is now jumping teeth on the front output sprocket.
I will let you know what I find. I will most likely get a different tcase from the local u-pull yard and replace the whole case. But I will pull it apart to find the cause. The weird thing is this truck only has 143,000 on it and shouldn't have a bad tcase already. The only thing I can think is the previous owner drove it a lot on dry pavement with the 4x4 engaged.
