power steering?
Old Jan 19, 2009 | 02:33 PM
boo-yaa138's Avatar
boo-yaa138
Question power steering?
i need to get new lines for my power steering and when i look them up they ask if i have a bendix gear box or a ford box. how do you tell which one i have?
Old Jan 19, 2009 | 07:41 PM
68horses's Avatar
68horses
2 bolts on the cover=Ford
4 bolts on the cover=Bendix
Gene
Old Jan 19, 2009 | 08:22 PM
mongoosekeith's Avatar
mongoosekeith
i am going to be putting power steering on my 69ranger and i already have a 79 f150 donor truck with the 300 inline 6 will all the components work on my truck?
also i have a 3 on the tree coulom but i have a 4 on the floor tranny so what colums will work on my truck??
Keith
Old Jan 20, 2009 | 05:19 AM
jowilker's Avatar
jowilker
also i have a 3 on the tree coulom but i have a 4 on the floor tranny so what colums will work on my truck?? Keith
Keith, Don't know what engine you have now or are planning to use when the swapping is done. Da big dummy will splatter you butt with parts numbers, but if you are moving parts from one truck to another you wont use any of them. The pump didn't change so if the hi pressure hose will reach, you should be OK. The return line is much less critical for fit.
The power steering column is about 2 1/3rd in. shorter than the non-power, and that applies to all. The difference is the ps gear has the fluid controls top front and that requires the column to be shorter. The 3 on the tree column will work, find a floor shift cuff for behind the steering wheel and don't worry about the shifting rods in the engine bay.
You can make it work.
John
Old Jan 20, 2009 | 05:23 AM
60F100's Avatar
60F100
You can use the column out of a later truck but the wiring is different. The length may also be a little different. The gearbox from the 79 should fit.
