I need help w/ solution on this...
Old Jan 19, 2009 | 01:35 PM
makomaker's Avatar
makomaker
I'm installing a 3 gauge mount under dash from Diesel Manor...well, my dash is two-toned med parchment, lighter on the top, and darker around the stereo and on down. DM sells the med parchment that match's the lighter, but not the 'DARK' medium parchment. DM told me to check with Ford, but I went by there and got the Ned and the third reader just fired pizza delivery dude...he said Ford doesn't make it anymore...whatever that's worth.
Anybody ever run across this before, or know where i can get the medium 'DARK' parchment paint. TIA Jay
Old Jan 19, 2009 | 01:38 PM
F250_'s Avatar
F250_
There are several sites which sell factory paint by factory paint code. If you look at the sticker on your lower door post, driver side, you'll find your interior paint code from which you can order matched paint. I was just researching that myself the other day and will look for a couple of links for you.
Here you go.....
http://www.expresspaint.com/helpful_...tion_guide.asp
http://www.tcpglobal.com/autocolorli...fordtruck.html
http://www.automotivetouchup.com/paint-codes/ford.htm
http://www.automotivetouchup.com/spr...t_matched.aspx
http://www.itpdiesel.com/store.php/p...or_Match_Paint
Tips on painting interior gauge pods...
http://theinteriorguyllc.com/paintin...luster-mounts/
Old Jan 19, 2009 | 02:13 PM
jeff7825's Avatar
jeff7825
The bottom part of the dash is the same color as the top is it not? It's just that part around the radio and everything that is darker.
Old Jan 19, 2009 | 02:14 PM
makomaker's Avatar
makomaker
No, the whole middle and bottom is darker...
Old Jan 20, 2009 | 01:48 PM
makomaker's Avatar
makomaker
bump...
Old Jan 20, 2009 | 01:52 PM
F250_'s Avatar
F250_
Have you checked out the sites for the paint availability from sources other than DM??
Old Apr 7, 2010 | 08:43 PM
pminne's Avatar
pminne
Rocky Mountain High
I have the same issue except for the medium flint (gray). I need "dark" medium flint. What has everyone else done to match the paint.
Old Apr 7, 2010 | 10:43 PM
bdrummonds's Avatar
bdrummonds
go to your local automotive paint supplier, most have interior paint displays and will have a book with the correct paint codes. I picked up a can of medium dark flint for like $9 from my local guy.
Old Apr 8, 2010 | 12:52 AM
CSIPSD's Avatar
CSIPSD
I took all my pods to a auto body paint shop... With a piece of the trim I wanted to match... 50 bucks later, its perfect and I am done.
Old Apr 8, 2010 | 07:46 AM
pminne's Avatar
pminne
Rocky Mountain High
Thanks guys, appreciate the info...
