speedo is out
Old Jan 19, 2009 | 04:10 AM
ryan f150 4x4's Avatar
ryan f150 4x4
speedo is out
i got a 92 f150 4x4 with a 5speed trans the speedo is off becous i have 35x12.50x15 tires on the truck and 410 gears how do i fix this .iI did a search and didnt get anywhere i know i need a speed o gear but more teeth or less
Old Jan 19, 2009 | 07:55 AM
Conanski's Avatar
Conanski
Start by finding out what speedo drive gear you have, then you can figure out what you need to go to using tables found on various sites. The Ranger Station dot com has a good tech page on this.
Old Jan 19, 2009 | 07:59 AM
jroehl's Avatar
jroehl
He's probably got an electronic speedo that runs off the VSS, and just needs to reprogram his PSOM.
To the OP: Do you have a mechanical odometer, or a digital? If it's mechanical, then follow what Paul (Conanski) said, otherwise, you need to look into reprogramming your PSOM.
Jason
