duct selection
Old Jan 18, 2009 | 07:40 PM
displacement4me's Avatar
displacement4me
duct selection
On my F150 w. a/c, I have control of fan speed and temperature, but the 'duct selection' is stuck on the dash vents.
If I switch it to anything else, I get the slightest breeze. Example, on defrost: the vents still blow full force, but there is enough of hot air flow on the windshield to clear the center about the size of a baseball. I think I clear more frost by exhaling on it.
I checked vacuum connections, but I have limited experience with the heater assembly. What could be the problem?
Old Jan 18, 2009 | 08:20 PM
Franklin2's Avatar
Franklin2
Do you have vacuum with the engine running? There is a line that hooks behind the engine on the firewall, and then runs over to the passenger side where it tees into a vacuum storage can, and then goes on through the firewall. I had a vacuum line come loose were it goes by the glove box before.
Here's a picture.
http://www.autozone.com/images/cds/g...3d800ce961.gif
Old Jan 18, 2009 | 08:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Perhaps I'm unclear on the older (pre '87) trucks but on mine the duct selection is done with a 'cable' operated arm to the left of the heater box close to the center of the dash.
One time when replacing the heater core, the cable jacket retaining clip slipped and I ended up unable to get the proper ducts as indicated on the heater control bezel.
Maybe the cable has unhooked from the door arm, the plastic arm is broken, or the door itself is jammed in place.
Just an idea of things to look for.
Old Jan 18, 2009 | 10:37 PM
ctubutis's Avatar
ctubutis
he's got a/c so his controls are vacuum operated
Old Jan 18, 2009 | 10:46 PM
displacement4me
yeah there was vacuum while running. the diagram looks useful - thanks. i'll look into it on the cab side
Old Jan 18, 2009 | 11:39 PM
86Stepside's Avatar
86Stepside
It could be the blend door in the ductwork, I had that problem also, air would only blow through the dash vents, but nowhere else.
