dash out
Old Jan 18, 2009 | 07:38 PM
whiteywhip's Avatar
whiteywhip
dash out
hello guys...havent been here i a while...got the injector problem fixed....everything works great.....now while driving back from the city.the dash went out....no gauges...speedometer....no tac....banged on the dash.....didnt come back on...been having this problem for a while but it always came back on....now no luck......talked to a guy and said maybe a cracked circuit board.....is this possible and a common thing with the 1999 ford f-350s???
Old Jan 18, 2009 | 07:47 PM
cangim's Avatar
cangim
There is a fuse that runs the gauge cluster as well, can't remember what it is tied into, but check that as well. I recall it would blow when the OD button would short out in the column.
Old Jan 18, 2009 | 07:52 PM
whiteywhip's Avatar
whiteywhip
thanks for that....i will check out the fuses....the od on the column shifter is still working fine...there is so much stuff under that dash...i am lucky to get my hand in there...i was thinking maybe a lose connector for that circuit panel....a fuse would be too easy.....thanks again
Old Jan 21, 2009 | 11:10 PM
whiteywhip's Avatar
whiteywhip
cangim...i checked all the fuses...under the dash and under the hood..all checked out good..looked in manual...said #19 and #2...both checked good....also the od is working...do you thing its a relay or something else??...truck starts...goes down the road fine....everything else ok ...just all the gauges dont work plus speedometer and tac out....i am really stumped....should i start ripping open the dash??
thanks for any help
george
Old Jan 21, 2009 | 11:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
thanks for any help
george
No, not yet anyway. Give it some time for someone else to see the post and reply. It may be more simple than you think.
Cracked dash circuit board? I don't know how this could happen, and I doubt it, but hang in there.The PCM is seeing what it needs to run the truck. This includes RPMs and speed. The signals just aren't getting to the cluster.
Old Jan 21, 2009 | 11:37 PM
Tenn01PSD350
This is for a 2001. I do not have a manual for the 99.
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="90%"><tbody><tr valign="top"><td>
  • All gauges are inoperative
</td> <td>
  • CJB Fuses 2 (5A), 19 (5A), 29 (5A) (Excursion only).
  • CJB Fuses 15 (5A), 19 (5A), 29 (5A) (except Excursion).
  • Circuitry.
  • Instrument cluster.
  • Instrument cluster connectors
</td></tr></tbody></table>Stand by while I drill down.
Old Jan 21, 2009 | 11:41 PM
Tenn01PSD350
Do you have normal startup warning lights that go out as they should?
  • Do the SERVICE ENGINE SOON, battery, safety belt, brake, or ABS indicators prove out?
Old Jan 21, 2009 | 11:47 PM
Tenn01PSD350
OK, I have to go to bed, but if your normal dash idiot lights do not light up, the manual says it is a fuse. From there we could go further.
Old Jan 21, 2009 | 11:53 PM
whiteywhip's Avatar
whiteywhip
yes when i turn on the key all the warning lites come on and go out while waiting for the glow plug start lite to go off
Old Jan 22, 2009 | 12:00 AM
Tenn01PSD350
Bummer.
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="96%"><tbody> <tr valign="top"><td valign="top"> Verify the instrument cluster connectors are connected correctly. Partial removal of the instrument cluster is necessary.
</td></tr> <tr valign="top"> <td valign="top">
</td> <td valign="top"> Verify the instrument cluster connector between the instrument cluster printed circuit and instrument cluster is connected correctly.
</td></tr> <tr valign="top"> <td>
</td> <td>
  • Are the instrument cluster connectors connected correctly?
Old Jan 22, 2009 | 12:02 AM
Tenn01PSD350
If the connection appears good, you need to verify voltage at the harness, Use a wiring diagram for your truck with KEOO. This is for a 2001:
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="96%"><tbody> <tr valign="top"> <td valign="top"> Measure the voltage between the instrument cluster harness side and ground as follows:
  • <table border="1" cellpadding="3" cellspacing="0"> <tbody> <tr> <th align="middle" valign="bottom">Instrument Cluster Connector </th> <th align="middle" valign="bottom">Circuit </th> <th align="middle" valign="bottom">Vehicle Application </th></tr> <tr> <td align="middle" valign="top">C250a pin 12 </td> <td align="middle" valign="top">640 (RD/YE) </td> <td align="middle" valign="top">Except Motorhome </td></tr> <tr> <td align="middle" valign="top">C250a pin 7 </td> <td align="middle" valign="top">1044 (WH/YE) </td> <td align="middle" valign="top">Except Motorhome </td></tr> <tr> <td align="middle" valign="top">C250b pin 3 </td> <td align="middle" valign="top">729 (RD/WH) </td> <td align="middle" valign="top">Excursion only </td></tr> <tr> <td align="middle" valign="top">C250b pin 3 </td> <td align="middle" valign="top">22 (LB/BK) </td> <td align="middle" valign="top">Super Duty F-Series only </td></tr> <tr> <td align="middle" valign="top">C250b pin 11 </td> <td align="middle" valign="top">640 (RD/YE) </td> <td align="middle" valign="top">Except Motorhome </td></tr> <tr> <td align="middle" valign="top">C250 pin 1 </td> <td align="middle" valign="top">640 (RD/YE) </td> <td align="middle" valign="top">Motorhome only </td></tr> <tr> <td align="middle" valign="top">C250 pin 6 </td> <td align="middle" valign="top">1044 (WH/YE) </td> <td align="middle" valign="top">Motorhome only </td></tr> <tr> <td align="middle" valign="top">C250 pin 6 </td> <td align="middle" valign="top">640 (RD/YE) </td> <td align="middle" valign="top">Motorhome only </td></tr> <tr> <td align="middle" valign="top">C250 pin 14 </td> <td align="middle" valign="top">729 (RD/WH) </td> <td align="middle" valign="top">Motorhome only </td></tr></tbody></table>
</td> <td>
  • Are the voltages greater than 10 volts?
Old Jan 22, 2009 | 12:05 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
There are two plugs behind the cluster. Might want to make sure they are pushed in all the way.
Old Jan 22, 2009 | 12:06 AM
Tenn01PSD350
Yes GO to B5 .
No REPAIR the circuit(s) in question. TEST the system for normal operation.
Old Jan 22, 2009 | 12:08 AM
Tenn01PSD350
Here's B5 for a 2001, and I am done.
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="96%"><tbody> <tr valign="top"><td valign="top"> Measure the resistance between instrument cluster C250b pin 5, circuit 676 (PK/OG), harness side and ground (except Motorhome); or between instrument cluster C250b pin 12, circuit 1203 (BK/LB), harness side and ground (Motorhome only).
</td> <td>
  • Is the resistance less than 5 ohms?
Yes VERIFY the instrument cluster printed circuit connector is fully seated. If so, INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation.
Old Jan 22, 2009 | 12:12 AM
whiteywhip's Avatar
whiteywhip
..thanks for all of that...i will get back tommorrow to let you know what happened....thanks
