90 f250 elec problems
Old Jan 18, 2009 | 03:21 PM
bubbahatton's Avatar
bubbahatton
i just picked up a 90 f20 4x4 351 from my uncle he is passing away not much longer so he gave me the truck i towed it to town but the igiton switch it just turns and it doesnt start they said it las ran 2 months befor i got it is ther a way to hot wire it i just want to see if it runs good if not i have to give it away becuse of the toys and my other trucks any help? u can call me 702.762.7700 im in vegas or email me at hatton777@yahoo.com
thank you for any help.
Old Jan 18, 2009 | 04:05 PM
baldboyford's Avatar
baldboyford
Do you hear the fuel pump when you first turn the key? Is the battery completely dead? If you do hear the fuel pump when the key is turned to the on position and assuming the battery is ok, turn the key to the on position and then under the hood take a large screw driver and cross the battery post on the fender well solenoid to the starter post on same soleniod. Before doing this make sure you have the tranny in park if automatic and neutral if manual (you will have to bypass the neutral safety switch near the top of the clutch pedal under the dash) and the wheels chocked/emergency brake applied! This will at the very least get the engine to turn over and if it is just a bad ignition switch the engine should start, although I'm not sure there may be some wires going to the ECM that are switch on/off by the igntion switch also.
Old Jan 18, 2009 | 06:15 PM
bubbahatton
thanks try all them the ign swith it will lock and then when u turn it its free then just stops i think they broke the ign swith i just need to know the wiring which ones start it i have alot of mech exp. i just hate elec. and plus it has one of those chips where u cant start it unless its in it u know..
Old Jan 18, 2009 | 07:48 PM
bubbahatton
and i got to looking that little box that sits on the end of the rod when you turn the engition its gone but the wire clip is there i called my uncle and his son said they took it off for another truck i said thanks i towed it about 150 miles to find that out? but i guess im going to the parts store or junk yard
