Sponsored by: Real Truck
Serpentine Belt
Old Jan 18, 2009 | 02:46 PM
brianlambert's Avatar
brianlambert
Question Serpentine Belt
I'm trying to figure out how to change my serpentine belt on a '03 250 4X4 with a 6.0 liter diesel. Does anyone know what has to come out of the way or be loosened in order to get the belt changed?
Old Jan 18, 2009 | 06:27 PM
HeavyAssault's Avatar
HeavyAssault
Removing the fan shroud will work wonders, not to mention the longest 1/2" breaker bar you are willing to buy or can find from a friend. The shroud will need the upper rad hose removed and remove some mount screws. This will help you when you put the new belt on, just follow your diagram under the hood and check it twice before you start the motor "just in case".
