Quick wiring question
Old Jan 18, 2009 | 11:27 AM
Casey_78's Avatar
Casey_78
On the instrument panel harness (the harness has numbers for each wire) ... Which wire and/or number is the Brake light? I was looking at the panel and it appeared to have 2 going to it plus a ground. Maybe its my imagination and I'll look harder tonight but its the last thing I have to wire on my new instrument panel (which I'll post later tonight or tomorrow)
Thanks guys!
Old Jan 18, 2009 | 01:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It's more complicated than that.
Which type of instrument cluster did you have?
Warning lamp, or gauges?
Basicly the brake warning lamp gets it's power from the Red/Yellow wire, and grounds through the porportioning valve switch when the switch is activated through the Purple/White wire.
Old Jan 18, 2009 | 01:42 PM
Casey_78's Avatar
Casey_78
I had all gauges.
Old Jan 18, 2009 | 02:06 PM
81-F-150-Explorer
Then this is what you should have.
The brake warning lamp gets it's power from the Red/Yellow wire, and grounds through the porportioning valve switch when the switch is activated through the Purple/White wire.
