I have a 2000 Ford Excursion 7.3 PDS -- hard start in the cold. I replaced the AIr Heater relay because it was not working -- and that helped a little -- but now I am still hard starting. I guess the next step is to check the plugs themselves -- do I have to remove the valve covers to do this?
Don
The Air Intake Heater relay doesn't help with starts with our trucks. It only activates for prolonged idling in cold weather. Since you have an EX, your GP relay is a module which is tied to your PCM, are you getting a SES light on the dash?
Here's a writeup by Jim (Megawatt) about the system. https://www.ford-trucks.com/forums/7...pr-system.html
Your Ex has the same system as the California models he mentions. It also has the procedure on testing the GP's. You test them by pulling the harness, not pulling the valve cover. If you have some bad GP's, then you have to pull the covers to replace. Good luck.
You can check the glow plugs without pulling the valve covers. There's a flat connector on the inboard side of each valve cover. Unplug the connector, grab a multi-meter set to read ohms, and ohm the front 2 and rear 2 pins at each valve cover against battery ground. Good glow plugs will read between 0.1 and 2 ohms.
Edit: Chris is right. The Ex has a GPCM, so that's supposed to throw a code for bad glow plugs or a bad GPCM. Do you have an check engine light?
No codes. That's what's confusing me. Last year I paid a guy because I was a goober when it started hard -- but at that time I also had a code --- he found that the passenger side had a short, loose harness, also loose and dirty connectors at the GPC Box and he replace those four plugs and the harnesses. This time I don't have a code -- the engine starts but chugs for about 30 seconds before it smoothes out. It does not do this when I plug in the block heater overnight. It also did it before it really got cold -- even around 40 degrees. Today I'm gonna put it in the garage and do the electrical checks (ohms) on the plugs. Any more advice?
When you start it in the morning do you do it just after the wait to start light goes out? The glow plugs run for a while after that light goes out. Yesterday it was 4* when I went out to start my truck, after the WTS light went out I waited a good minute and then started it up. No romps at all. I am running dino also.
Read through the thread that Chris had posted the link to. It will give you a better understanding of how your system works.
When you say the engine chugs for about 30 seconds, does it kind of romp up and down? Sounds like it may just be an oil issue. You might try a synthetic 5w-40 oil. Many here have cured the romps by switching to synthetic in the cold temps.
The chugging engine idle on cold mornings is often referred to as the "romps." I can be glow plug related but my money is on the weight of oil you have. 15w-40 dino oil in cold climates will be pretty thick and our engines use oil pressure to fire the injectors. A thinner weight oil like 5w-40 Synthetic will be help tremendously for cold starts. The fact that you mentioned that if you plug it in helps with the romps or chugging leads me to think that your GP system is OK but your oil is just too thick on the cold mornings. Like Jim suggested, make sure you are allowing more time for the GP system to warm the cylinders before trying to start. That will help as well.
