Do i need exhust tips?
Old Jul 10, 2002 | 06:31 PM
stover007's Avatar
stover007
[updated:LAST EDITED ON 10-Jul-02 AT 07:35 PM (EST)]Would you stick exhust tips on a 351w with flowmaster 40 to change the sound at all? If so what will the change it to and what ones would you get?
Also which 40 series should i get i want someting loud i dont know which one to get as to example 3" center inlet/center outlet
3" offset inlet/center outlet
3"offset inlet/outlet
3" offset inlet/oulet, aligned
Old Jul 10, 2002 | 06:36 PM
RBrendel's Avatar
RBrendel
[updated:LAST EDITED ON 10-Jul-02 AT 08:34 PM (EST)]i have no muffler on a 351w. it is loud but not to loud. sounds really healthy. 2.5 piping dualed out from cats to 3 inch echotips. a k&n airfilter is a must for this setup. it made mine sound 100% better. im not sure of your year but i dont know if you have the dual cat setup, if you do do what i did, i didnt have to mess with those damn cats or replace them. i just junked the muffler. if your cats are not restrictive a 40 series will be really loud and 3 inch echotips will make it deeper and sound better.
Old Jul 10, 2002 | 10:18 PM
MustangGT221's Avatar
MustangGT221
The two cat setup really muffles the sound. I just put an amerian thunder cat back on mine, started it up without any pipes just the one coming off the second cat and it wasn't 1/2 as loud as I thought it would be. To tell you the truth, a 40 series does very little muffling of sound, most of it is from the cats.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Old Jul 10, 2002 | 10:19 PM
MustangGT221
