Seized motor
Old Feb 13, 2009 | 03:49 PM
FORDPOWER666's Avatar
FORDPOWER666
So finally got around to pulling the rocker covers. A couple were stuck down but not very much. got them loosed up and stuill only rotates about 3/4 of a turn. So either something in a couple of the cylinders or something else.... I guess my nexted step is removing the heads?
Old Feb 13, 2009 | 07:46 PM
Redmanbob's Avatar
Redmanbob
I'd pull the heads before forcing anything 4 sure. 3/4 of a turn is really odd. Do us a favor and pull the dizzy out then try it. This will free the oil pump from the equation. Easier than pulling the heads too.,
Old Feb 13, 2009 | 08:44 PM
Putt's Avatar
Putt
Could it be something in the transmission, clutch, bell housing?
Old Feb 14, 2009 | 10:47 AM
FORDPOWER666
The Dizzy? What is that? I thought something might be in the clutch area... Does not feel like it. its quit a thud when it hits.... But i will have a looky... Thanks
Old Feb 14, 2009 | 11:05 AM
Redmanbob's Avatar
Redmanbob
Dizzy=Distributor, is connected to the oil pump via the pump shaft. It's a long shot but an easy check to rule that out.
