If your going to use it for some offroading activity you might want to swap out your open end axle for for a limited slip one. I'm actually going to be doing that in about a half hours time (got the truck all jacked up and swapping out a 3.08 open end () for a 3.55 LSD). Its not too complicated, but it can be a pain if your hardware is rusted (U-bolts and such). Its also not very expensive if you do it yourself either, I got mine for 500 bucks here in Canada and I'm sure you could find something cheaper in the US. Other than that the only cost is a little brake fluid and differential fluid and friction modifier.
Wait you're swapping the entire differential to get limited slip?
You could have gone with a limited slip carrier, or an aftermarket locker.
Either way good luck on the install
Thanks for good luck it went really nice and breezy. 3 hours then road test. I swapped it out not only for the LS but the gearing too. I priced out alot of stuff and this avenue was the cheapest. Makes a nice difference, lots more grunt than the 3.08 and the LS makes for mad snow donuts in the parking lot.
Cool, glad it worked out for you. What did you pay for the rear end if you don't mind me asking.
i have 3.55 gears with open diff also is it really that easy just to swap?
