2003 E250 1 Ton?
Old Jan 15, 2009 | 07:53 PM
Concep29's Avatar
Concep29
2003 E250 1 Ton?
Hey All, I'm looking at buying this 2003 E-250 Cargo, the guy says it's a 1 ton. I thought all 250's were 3/4 ton?
Isn't the E-350 the only 1 ton?
Old Jan 15, 2009 | 09:29 PM
sphinx's Avatar
sphinx
150/1500= 1/2 ton
250/2500 = 3/4 ton
350/3500 = 1 ton
there are light and heavy versions of the 3/4 ton, at least in pickups. different axles and springs allow a heavier GVW but its still not a one ton.
Old Jan 25, 2009 | 12:26 PM
wiscvanman's Avatar
wiscvanman
i have an 04 e250. mechanic says it is built on the 1 ton chassis and requires 1 ton parts. when i look up suspension parts they fit the e350 also. gvrw is 8660 though. had 2900 lbs in it and the headlights went high.
the 250 has a base engine of 4.6. the 350 a 5.4. perhaps for the extra 1000 lbs the 5.4 is required with all the other components the same.
didn't really help ya did i?
i would say it is a 3/4 built on a 1 ton chassis.
Old Jan 25, 2009 | 01:26 PM
Conanski's Avatar
Conanski
The 1-ton trucks do get a bigger frame, the 3/4 ton trucks are usually just a beefed up 1/2 ton frame with heavier springs and axles.
Old Jan 25, 2009 | 05:44 PM
94E1504.9L's Avatar
94E1504.9L
3/4 ton vans are now built on 1 ton chassis and in 2008 even the 1/2 ton van has 1 ton wheels that are 8 bolt and a one ton chassis
Old Jan 25, 2009 | 09:26 PM
Conanski's Avatar
Conanski
Ahhh... No.
Laggy
Jun 3, 2017 06:18 PM
Tony.
Mar 25, 2017 07:16 AM
mmeserve83
1947 and Older Ford Trucks
Nov 26, 2015 01:36 PM
jdhudall
27
Jan 28, 2013 02:55 PM
83stepside32784
Sep 16, 2005 09:54 PM
