Transmission Troubles
Old Jan 15, 2009 | 05:47 PM
JeremyKS's Avatar
JeremyKS
4wd Low
I have a 79 f-100 with an auto transmission. I recently been having problems with the transmission. You can feel the transmission shift through the gears but it will only drive in reverse. Any suggestions what might be wrong?
Old Jan 16, 2009 | 09:53 AM
JeremyKS's Avatar
JeremyKS
4wd Low
no ideas? or is it new transmission time?
Old Jan 16, 2009 | 10:19 AM
GLR's Avatar
GLR
What trans? fluid check? filter plugged? Condition of fluid will give you an idea whether or not to drop pan..I know on a C-4 if fluid (Type F) is low it will only work in rev. Could try band(s) adjustment. If all fails- new trans.
Old Feb 16, 2009 | 04:55 PM
JeremyKS's Avatar
JeremyKS
4wd Low
I believe this is a C6, if I drop the pan and change filter how much fluid will the transmission hold?
Old Feb 16, 2009 | 05:42 PM
427 fordman's Avatar
427 fordman
If your fluid is full make sure you smell it. If it smells burnt time for repairs. As far as how much it holds you better make sure what it is first then look in any older ford manual and you should be able to find it.
