Headers for my application
Old Jan 15, 2009 | 04:15 PM
sbable's Avatar
sbable
Exclamation Headers for my application
Hey guys!
My 1964 f100 2wd step side was highly modified before i bought it. The front half of the frame was cut off, and a 75ish lincoln front end was welded on. Why you ask. Because disc brakes mustang II type suspension, 460 ci motor c6 trans was enough to make them do it i guess.
Anyway, i was looking to put a set of headers on it. but the manifolds are so so close to the frame i dont think it is possible. Anyone have this application that has a set of headers i can try? i work at Summit Racing so i have access to many sets of headers. Pls let me know if anyone has anything. Thanks
Old Jan 16, 2009 | 03:10 PM
airharley's Avatar
airharley
Check to see if a set of headers are available for the same year make clip you have installed. If not the next closest thing would be a set of headers meant to swap a 460 into a fox body mustang. They hug the engine pretty good.
Old Jan 16, 2009 | 03:41 PM
Customcab's Avatar
Customcab
I definetly recommend that you go with shorties. As mention check what application where avaiable for front clip, an go from there.
